http://i1167.photobucket.com/albums/...psupihzblg.jpg
Cracked a piston :( Running too lean I think.
Ill change it on friday or saturday in time for autoheroes.
You have some determination think I'd have binned it ages ago!ha fair play!
The feeling of boost is keeping me going haha. At the end of this I'll have a fully rebuilt engine from fixing all the parts ! :laugh:
pure sickener dude. stick at it though!
Cheers. It will live again.
Engine out.
http://i1167.photobucket.com/albums/...psinmthvfy.jpg
Found This.
http://i1167.photobucket.com/albums/...psqdua9btd.jpg
Changed it.
Engine back in.
http://i1167.photobucket.com/albums/...psmu4qoxdf.jpg
In 6 and a half hours. Not bad for some lads in a shed and a halfrauds toolbox.
It has never ran so well. F*cking delighted.
So far, 100%. Boosting 7psi with a new map and it is mad fast. I'm in love.
Heres some shots from autoheroes. Cant believe how good it looks.
http://i1167.photobucket.com/albums/...psh9tzupjx.jpg
http://i1167.photobucket.com/albums/...ps1trugthv.jpg
http://i1167.photobucket.com/albums/...psdodbj2jn.jpg
It's pretty much done for now. Going to enjoy it for a bit. Next on the list would be a fuel pump and a new roof, but theres no rush.
Bit of a launch. Stuck to the seat! https://youtu.be/Nr_BLG9WlMY
Saw ya revving this in mondello yesterday, the lads I was with were scratching their heads listening to the flutters out of it :D
Really really cool looking car in person too
Hahaha thats gas!
Thanks, man!
Sleepin' it real
Non mx5 or drift related, I just want to show people the sheer size of a citroen c4 vts back box.
About the size of your average house. The one on the right is an everyday humble aftermarket backbox.
http://i1167.photobucket.com/albums/...psotcmdliu.jpg
Car is looking sweet, nice to see you sticking with it and rebuilding the engine, what arches are they? im looking into a set but dont know what route to take
STOP BLOWING IT UP lol
Good work man bring it to cork ASAP for a shoot
Thanks boys. Yet another engine will be bought soon, and it will be the last one! Or a new head, we'll see.
Cork is on my list of places never to go, but I could make an exception for races.
Also, they are from TheDriftShop on fb. Just cheapy universal ones and they are perf!
Update.
Got these.
http://i1167.photobucket.com/albums/...psvfhbqzfh.jpg
http://i1167.photobucket.com/albums/...psmslent9s.jpg
Deadly.
Those coilovers look nice, similar to teins! Have fitted them yet?
Very nice.
Yeah fitted them last night, Dave. They look sick.
On the front, the wheel is tucked and I Havnt put any weight on it yet! So they might have to come out again to adjust preload/cool height.
Yeah you have them wound right down in the pic ha ha car is probably on the ground when you put weight on it! Ha ha
Be interesting to hear what the ride is like instead of the usual meister mx5 coilovera bandwagon.
Yeah it'l be interesting!
More pics of them installed.
http://i1167.photobucket.com/albums/...psenzyewai.jpg
http://i1167.photobucket.com/albums/...psdtrm8grc.jpg
http://i1167.photobucket.com/albums/...psgtt7ccqg.jpg
That pic of the wheel is tucked even with no weight on it! I'll have to do some height adjustments haha
Tiny update.
Got the new engine cleaned up and dropped in with the help of some mates. Started up first crank!
If I gain anything at the end of this, it will be that I can swap an mx5 engine over in record time !
http://i1167.photobucket.com/albums/...pspnchtzfi.jpg
Particularly happy with the colours, if anything!
http://i1167.photobucket.com/albums/...psmklrctop.jpg
http://i1167.photobucket.com/albums/...pstx38fsll.jpg
Still have to mount the gearbox and diff up properly. Fiddle with the suspension a bit and get it mapped before its drivable. Getting there though :)
Spent the majority of a day underneath the car.
Got the diff in, ppf and the rest all bolted up. Dropped the car down, started it up and moved it. Delighted.
All seems well
http://i1167.photobucket.com/albums/...ps9j8obqn5.jpg
http://i1167.photobucket.com/albums/...psurcgyohm.jpg
http://i1167.photobucket.com/albums/...ps7sa9hqe6.jpg
http://i1167.photobucket.com/albums/...pstrgeddrf.jpg
At least the diff wasnt marked too much.
Jes you really have some patience! Fingers crossed for reliability this time!
Patience is thinning.
Had to change the water pump after that.
If anyone wants to offer money for this, go ahead!
Le update.
So since then I decided the hell with the turbo, I want ITBs. So I sold all the turbo bits. It was tough in the feels because I spent a year working on it and a lot of the parts I made myself. But I was mostly relieved.
My mate had a set of levin Blacktop ITBs laying about so I decided to use them.
Picked up a cheap second hand exhaust manifold that needed some welding.
https://uploads.tapatalk-cdn.com/201...122be28c0d.jpg
I then got onto DanSt engineering in the UK to make up an adapter from the mx5 to the blacktop ITBs.
He was prompt and the quality is second to none. https://uploads.tapatalk-cdn.com/201...7cff4c7cf9.jpg
Some modification was needed on the fuel rail. The lines where interfering with the ITBs. I cut off the return line completely and ran the fuel line straight from the FPR. I cut off the Inlet line and rotated it to it cleared everything and got it welded back on at work. I've no pictures of that at the moment.
The throttles went on with ease.
https://uploads.tapatalk-cdn.com/201...925508e7ea.jpg
https://uploads.tapatalk-cdn.com/201...8be5808ed5.jpg
Since it wont be mapped using a MAP signal, I wasn't worried about the vacuums for each throttle, at least for now. So the two vac nipples on cylinders 1 and 4 were routed to the FPR and MAP sensor in the ECU (not sure if it's actually doing anything).
I'm using the throttle position sensor from the mx5 auto engine but it is to be mounted 45deg from a levin tps, so still need to make up a bracket for that. To get it running, it's just held on with cable ties.
The throttle cable was a bit of a Jeff but got it on and working with some gunthering. Most likely get one custom made at a leather time. It's on the list.
After getting a map from a mate with an ITB 1.6, I changed around the details and with fresh oil and plugs it started up easy enough. With some tweaks to the fuelling it starts and Idles happy enough for now.
I got some cheapy velocity stack that liven up the bay.
https://uploads.tapatalk-cdn.com/201...ff0cea5b54.jpg
https://uploads.tapatalk-cdn.com/201...19498794a1.jpg
https://uploads.tapatalk-cdn.com/201...5927f1a68d.jpg
There's a few small bits to be done and then it's finally going off to be tuned. Not looking for big power. Anything over stock will be grand. I just want to drive the thing again!
Really happy with it anyway and it sounds amazing, the intake and the full straight through exhaust.
My plan is to have it on the road for the summer. And maybe sell it for the next project ( Queue massive regret).
https://uploads.tapatalk-cdn.com/201...80473995cd.jpg
