Bubble1984 is looking at it tomorrow so it should be all sorted. :D
have a look for start signal at the ecu the unloader relay can fuck up and not sent a start signal to the ecu causing it to flood, its and orange wire in the small white plug at the ecu it should come live when you crank the car
was tinkin of dat, my skyline gave dat trouble for 6 weeks before i discovered dat wire.ill let ye know wat i find. i tink deres a fuse 4 dat wire nd all. pin 34 metinks or 43 on d skybus.
I had the same problem with mine greg
wat i did was tried three 3 and it was only when i did all three it worked perfectly
- New battery
- New walbro 255 fuel pump
- starter motor refurbished
starts perfect every time since
And not to much expense in all that either
It started on the button this morning apparently. Good job Reuben. :D
tanx, found a lot of 'loose ends' in d car dat are sorted now, but a full check over wud help:D.
but wit regards to starting, ecu was gettin crank signal etc.but dat FPR which was regulating fuel on the way back to the tank after it was already regulated wasnt helping.
also d vacuum lines to the nissan regulator wer more holy dan Tony Montana at d end of Scarface. :eek:
Good man Ruby :D
Some retards should not be left near a car!
Bump!!! It's not starting again.
