if you dont wanna go messing around with it it is as easy just to pull off the 5 stud wheel bearing 4 19mm bolts from the inside around the half shaft and one 32 for the brake shoe pivot then just bolt it all on to the car
ah feck that its less work jus to press the ball joint out..im lazy :D
