trying to remember when i did it, but did you bleed all 3 nipples fro the top down ?
did you bleed with the pipe into a bottle and submerged in the fluid ?
did you take some of the adjustment out at the pedal ?
if so, as said before it probably is drawing air somewhere.
bleeding normally is a pain and can take a while to get right !
hope this helps
Quote:
Originally Posted by
yowdy
wel wot woz it
it was wel air locked took agers to get pressure bk an had to adjust the master cylinder were it connects to the clutch pedal
i thought that would do it ! ;)
