From what i remember ALOT of Tomei and GReddy stuff in that car when i had it, Tomei cam's,Injectoers,G Reddy turbo,manifold and intake,forged internals,......but who knows might not even be the same engine as the time i had it,just simply the engine cover moved over.
Been busy past couple days giving a hand here and there to the other lads and havent really got to mine to make any more real changes.
http://i1312.photobucket.com/albums/...psy3jrjwki.jpg
We burned out the bushes on one of the 180's.
http://i1312.photobucket.com/albums/...psonee2oyz.jpg
Fitted all new arms and polybushes, hoping to do this to my own soon....
Started proper looking into my own car to try make heads or tails of the past stories, found some very good evidence as to what may have happened it.....
http://i1312.photobucket.com/albums/...psmgbu3ub5.jpg
Came from Charleville anyway....
http://i1312.photobucket.com/albums/...psh1pur0zd.jpg
Finally found some rust when I searched high and low on it, the usual 14 boot well, easy fix...
http://i1312.photobucket.com/albums/...pskjxgyfbl.jpg
Makes me sad that previous red glowing up at me....
http://i1312.photobucket.com/albums/...psu6symp2r.jpg
Cant wait to get at that battery bracket with an angle grinder and get sanding the engine bay...
http://i1312.photobucket.com/albums/...psuxluepyv.jpg
Nice little after market anti roll bar...
http://i1312.photobucket.com/albums/...pslpzpnocy.jpg
That colour glowing at me again made me look even deeper into things....
http://i1312.photobucket.com/albums/...psqhuaoidz.jpg
And think I found the reason why it was sprayed white... She mustve got a tap! Poorly beaten out with a hammer but handy enough with filler... Guess that red colour was too dear to match and ended up doing it on the cheap... Which came in the colour white...
Hopefully dropping the subframes in the next two days. Then shultz the underneath and paint up the subframes... Get cracking on the engine bay then. :)
what about the big hole in the block the conrod made from drifting it down the port with the big ends rattling xmas day :cool:
Have been busy the past while and havent really got a chance to update this, we extended the new unit and 4 more of our buttys have moved in so its been all hands on board the past while. Heres the update....
http://i1312.photobucket.com/albums/...psjses05et.jpg
Picked myself up a mint Sr20det, straight out of a 180 brought in from Japan that hadnt even been vrtd yet. 60k miles. Loom currently been sourced for me by Japenese Performance....
http://i1312.photobucket.com/albums/...pse1lse4hg.jpg
Cracked open my old gearbox to find a nice little ORC Ogura clutch....
http://i1312.photobucket.com/albums/...pszw634ue5.jpg
Unfortunately, part of the deal with the new engine was he got to keep the box and clutch.... Dammnit....
http://i1312.photobucket.com/albums/...psarc8ofiu.jpg
Got into the new part of the unit and work got immediately underway....
http://i1312.photobucket.com/albums/...ps08yb6xqb.jpg
Front subframes got dropped
http://i1312.photobucket.com/albums/...ps6nallbvw.jpg
Stripping back of the major surface rust began....
http://i1312.photobucket.com/albums/...ps1arc9akn.jpg
Got the arches back to get a proper look at where it needed to be rewelded...
http://i1312.photobucket.com/albums/...pst4elmfcd.jpg
Only one way of tidying up this, and its off to get tubbed in the coming week or two!
http://i1312.photobucket.com/albums/...psrjb4cxlh.jpg
Etch Primed & High Build Primed what I had ground back to bring up a smooth finish...
http://i1312.photobucket.com/albums/...psg1ns7wjb.jpg
Quick spray of stone chip sheild for the time being....
http://i1312.photobucket.com/albums/...psi3bhpdms.jpg
http://i1312.photobucket.com/albums/...psczv6fne9.jpg
http://i1312.photobucket.com/albums/...ps685b13e0.jpg
Now to do something with the inside....
http://i1312.photobucket.com/albums/...psc53158b6.jpg
Quick wire brush and Etch Prime...
http://i1312.photobucket.com/albums/...ps78705296.jpg
http://i1312.photobucket.com/albums/...ps209acea8.jpg
http://i1312.photobucket.com/albums/...ps829f7bcd.jpg
Small bit of welding in the boot and a quick wire brush back, high build primer and a lick of raincoat... Tidied up a small bit I suppose...
http://i1312.photobucket.com/albums/...ps368efd2a.jpg
http://i1312.photobucket.com/albums/...ps97b3d149.jpg
Out came the back subframe...
http://i1312.photobucket.com/albums/...psc1b3df94.jpg
Found some solid bushings already put in.... welded in I may add... the japs mean business....
http://i1312.photobucket.com/albums/...ps698238b2.jpg
Hupppp she goes' ...!
http://i1312.photobucket.com/albums/...psef76e1d4.jpg
Nice wire brushing and a healthy coat of Schultz... Lick of clear coat to harden it up now today.... http://i1312.photobucket.com/albums/...ps89b0382d.jpg
Even the gearboxes got a little TLC...
Hopefully off to be tubbed in the next fortnight, in the meantime subframes will be stripped, cleaned and repainted... and treated to some new polybushes.
A friend of mine had that in charleville back in 09 a fair pony she was lad well ware lookin forward to seeing how it turns out
Fair fucks to you lad your doing it all properly anyway ill be keeping an eye on this. The washers welded to the subframe means that your going to get good height on the subframe so all the better!
Just a little update so far on how the builds going... New arms on the way hopefully arriving tomorrow so full speed ahead cleaning up the subframes and replacing the bushes.... Lick of paint here and there, makes all the difference in cleaning it up....
http://i1312.photobucket.com/albums/...ps44b1ccec.jpg
Got me some driftworks polybushes....
http://i1312.photobucket.com/albums/...ps682c5a85.jpg
Cleaned up the wishbones....
http://i1312.photobucket.com/albums/...ps1240239f.jpg
Sprayed up the rear subframe...
http://i1312.photobucket.com/albums/...psd0b769e3.jpg
http://i1312.photobucket.com/albums/...psa189f55e.jpg
Anti roll bars got a seeing to...
http://i1312.photobucket.com/albums/...psd97354b1.jpg
http://i1312.photobucket.com/albums/...ps021f7d30.jpg
Actually only discovered as i was wire brushing the subframe, theres some extra support plates welded on... Japs meant business
http://i1312.photobucket.com/albums/...ps160dfc42.jpg
Finding I had solid diff bushins was a plus too...
http://i1312.photobucket.com/albums/...ps48b9abf6.jpg
http://i1312.photobucket.com/albums/...psb2a71d6d.jpg
Attention to details becoming a big factor...
http://i1312.photobucket.com/albums/...pseb9b9607.jpg
Second lick of paint tonight, made it a little goldier....
http://i1312.photobucket.com/albums/...psed7c4fd9.jpg
Diff got a clean up...
http://i1312.photobucket.com/albums/...ps6489eba5.jpg
http://i1312.photobucket.com/albums/...psf65c540f.jpg
Black'll do, nothing crazy...
http://i1312.photobucket.com/albums/...ps923d9a1e.jpg
Picked myself up two front tein coilovers... Now to source two rear...
http://i1312.photobucket.com/albums/...ps8dd79fa2.jpg
Must say taking out the old ones is some pain in the arse.... But nothing beats the feeling of getting in the new ones....
http://i1312.photobucket.com/albums/...psfd975eee.jpg
Now just to wait for the new arms coming tomorrow.... Clean up the front subframe, get it back rolling and off to be tubbed... Wont be long now and it'll all start coming together and I can get the running gear in...
Class car mate werd u get the jap plate made? Or did it come with car?
I'll be selling the teins out of my car if you're interested in the rears
