maybe thats the cars way of telling you slow down scamper???? bit like your body trying to tell you give up contact sports!!! how's the shoulder anyways?? think glassman could stick yet as another nickname
Aw i dunno jerry, rite now i dont see the end of this 180 project ever happening, soooo much to be done, its at that stage.
As for the shoulder, ill live, wasnt as bad as first expected, still bloody sore tho.
Have you tried sitting in while someone hoses it, maybe take a seat out and pull the carpet back, a get a torch ya should see something.
Water travels through cars ya'd be surprised where leaks can come form
Hope ya get it sorted
Or as said above interior rad
Bottom of the dash is out, carpet is out, seats are out, all trim is out, it is bare as can be.
Sat in it today with the hose beating off the exterior from all angles for a good few minutes.
Stopped, couldnt see anything, then 5 min later low and behold, water starts appearing, but from under the rubber mat that is all around the steering column, under carpet.
Driving me fucking mad
is it brake or clutch fluid?? cant memba if its the kind of setup on a 180 that can leak into the footwell but just check it out..
Its def not either of the above u said jimmy, have that checked, its 100% water
Rear window washer leaking from the pipe going to the back of the car? (thats if it runs in the car, i duno?)
Nope dont have any in the rear!
Sorry again to hijack this but no point starting another thread. I just had a look and I can see light from the footwell. Its where the loom heads out to the wings/wheel arch. Its a tiny opening and I dunno if it could allow such an amount of water in but im probably wrong.
Car hasnt moved since last night so I was hoping to see it dry but its still soaked. But in saying that anyone in north Dublin will know how bad the rain was, she drove through a lot of large puddles on the way home so that may be why its still wet?
Is that the pipe that runs along the drivers side of the car from the drivers footwell? Maybe ill check that too if the rain stops
Scamper I hope you find your issue, its a pain in the hole! :(
well i can understand when ur driving, as the wheel would be throwing water threw that hole, where as mine has been parked up the last 4 months, and the water still gets in
