polish FTW;)
i was tinking of doing my ssr centres the off white pearl of my car
is it hard to break apart & rebuild these rims without having any airleaks?
also is there a special bit/tool to open the nuts?
dont wanna ruin them using a hex/allen key bit & roundn them off etc.
no bother really lad,didnt have to use hen/allen key at all,i just loosened the 12mm nuts on the back and you could hold the front with your hand,usesum wd-40 on the first. then gently tap the centres out with a rubber mallet and it should fall out, make sure to tighten them well when you put them back 2gether tho.
how did this go?
