it is expensive to work on these arches, and maybe to see very minor returns.
im sure i could rock up to 10 or 10.5 with maybe a 0 to +5 offset.
for got to ask, what are your wheel specs again? You need to lose about 25mm minimum i'd say to fit
there is a chap called jjo5y on DTDirl that specialises in custom metal work...maybe give him a shout? to look at making arms?ive no number though sorry
There's no aftermarket arms on mine at all. The only camber that is there is from the coilovers as low as they can go.
I've had 10.5j +30 on the back of mine and they had feck all poke and were hitting the coilovers going over bumps. The 10j Volks I had on with a 40mm spacer which made them -12 stuck out a good bit but your arches would cover them. :)
