Nope ro, its on sxoc
when do ya think ya could let the oilcooler go stevo:)
Bump..........................:eek::p:D
Rite lads finally made up my mind to break this car, loads of bits with less than 100klms on them!!!!!!!
Want to keep everything needed to run the engine till its sold so it can be seen running!!!!
First come first served lads, pics up tomorow or as things are requested.
Whole car for breaking
HKS coilovers with top mounts MINT condition €550 Will not separate!
HKS Adjustable actuator €130
Cusco front strut brace €85
Everything needed for 5 stud conversion €350
Coilpacks €140
Gearbox (Perfect cond)€275
SR20det Engine with acl bottom end bareings, rocker stoppers, ported head, arc oil cap, new water pump and altinator only done 100klms since rebuild Head freshly skimmed aswell can be seen running €1000
Sparco bucket €80 (held for s13 ste)
Raceland seat €80 with s14 rail
Personel steering wheel €75 with boss and personal gear knob
Nismo 16" 2 piece alloys €275
2 Sparco harnesses €50
Welded diff in casing €180 (only done last week and has silkoline oil in it)
Blitz Boost gauge €40
Brand new engine damper €80
Rear lights €100
Head lights €60 each, the pair €100
Indicators €50 for the pair
Doors x2 with glass €100
Standard Front bumper €30
Mirrors €40 each
Dash with heater control panel €70
Ignition barrel with key €70
Bonnet €75
Boot €65
Shell??
Front/back windows €100 each
Mint rolling shell with the coilovers €1500
Bump car getting stripped tomorrow lads so everyone that i was keeping bits for fire me a PM and come get ur stuffs :D:D
Will that boost gauge go straight into a 180??:)
And if not, what do i need??
Thanks:D
by any chance do you have an all.. radiator?
Bump lads, first post updated:)
5 stud conversion - Disks hubs calibers wishbones €350
Coilpacks €125
Oil catch can €45
ECU and LOOM €150 (S14 vvi)
Gearbox (Perfect cond)€250
Exedy 3 puk paddle clutch €150
SR20det Engine with acl bottom end bareings, rocker stoppers, ported head, arc oil cap, new water pump and altinator only done 100klms since rebuild Head freshly skimmed aswell can be seen running €1000 or €600 the without the head done!!
Sparco bucket €80
Sytec Brand new still in box fuel pump 255lph €80
Rear lights €100
Mirrors €40 each
Bonnet €75
Boot €65
Shell??
Standard fpr €30
Starter motor €50
Alltinator €50
Mint rolling shell with the coilovers €1300
Mani, turbo, elbow, downpipe, De-cat, front mount Deposit taken
strut brace and engine damper sold :p
stevo sorry man i suck balls at collecting parts. im up the walls in work il give ya a shout as soon as i have time
can you send me your number mark 0867958998 thanks
story stevo what mileage is on the coilovers? are they in good nick? any knock or leaks?
All PM's replyed to lads:cool:
up ya go:D
No one wrecking bits off there cars:confused::confused:
Gearbox sold, justjap ftw!!;)
pm sent ;)
.............................. :D
Much for the 2 front wishbones for meeeeee stevo?!
Damn, knew i should have txted ya instead;)! leave it with me sure:cool:
any go on the wiring stev:confused:
bump............
how much for everything needed engine wise to put into a 200sx ??
Rite so sum more bits gone :D
Ecu and loom
Clutch
Catback
Strut Brace
Sparco seat
is the bit im after gone stevo
