righto so small update car is nearly allstripped now just to get under it tonight and drop the old petrol tank and all the old fuel and brake lines :happy) job ive been putting off for a bit
engine bay and interior fully stripped few small bits left to come out not much thou
http://i176.photobucket.com/albums/w.../Image0114.jpg
http://i176.photobucket.com/albums/w.../Image0115.jpg
so last nite in another feat of trying to avoid getting under it i decided it was time the car started to go on a crash course diet:D
front valances chopped off theres probably more to go when i start to mate the intercooler to it but it,ll do for the min
http://i176.photobucket.com/albums/w.../Image0116.jpg
and finally the rear took a battering(rrfl: im gonna make all the back off it completly flat floored to leave loads of access to the diff suspension arms etc etc so im chopping the rear quarters and pockets off it boot well will be going basically anything tats not needed is going in the bin
so wat i started wit orginally
http://i176.photobucket.com/albums/w.../Image0113.jpg
after a while of cutting
http://i176.photobucket.com/albums/w.../Image0112.jpg
and just a pic of actually how much is being cut from the back end:D
http://i176.photobucket.com/albums/w.../Image0111.jpg
tis is how i left it last nite more to be done tis evening so maybe another update later on
and on doing a small bit of research the differences between weight on the two car is unreal from a small bit of google work its between 200 and 300 kgs so in comparsion tats like 200 to 300 bags of sugar so the power to weight ratio should be extenmally good on tis shell when finished and should see a lot quicker a car on track witout having touched the engine so all good on the pocket and also for reliability as i wont need to run as much power;)[/
