pretty sure carpo had a nice set of ssr mesh in 14's?
dont think anyone mentioned it, but I'm looking at buying 50mm spacers on driftworks.. nice bolt on jobbies, to suit 4/5 studs.
bout 110pounds posted, for 2.
worth a look if your stuck...
any wider any the inner arches will have to be cut on the back, bit of a headache, used to be mine!:)
didnt realise you were'nt cutting arches, I am..
as the lads said, bigger offset of wheels, or even some
small 20mm spacers just bring them out, small spacers
like that don't need to be savage quality..
id now try donedeal for a wide drift car getting broke and
send a text dude, worth a shot.
SMALL 20mm spacers!? thats an inch giles ha for that size you need bolt on spacers that are hub centric to ae86 which is like 61mm
AE86 - 4x114.3 with thread pitch of m12x1.5
180/S13 4 stud - 4x114.3 with thread pitch of m12x1.25
so spacer will fit on but you wont be able to bolt it thus its useless
10mm shim(non-bolted) spacer is the max w/o hub centric i think as iv had mishaps!
Options starting at the cheapest..
Pull them off and fill the holes as the original body is un-cut (i gather?).
2.- buy stupid big gay spacers circa 170-250e new,less 2nd hand.
3, buy mega negative offset 9j 15's from japan.
4,buy mega above in a 14"andcomplete the 1st option
5 i spotted these...http://www.ae86irl.com/forum/showthr...ight=wide+mesh
If i were you id genuinely pull them CBY arches off a fill the litlle rivet holes.
the offset is high-ish but they can be reversed then refurb'd weld the original valve hole, drill a new on the new side then balance then and wayhay! your away!
But if you havent the money
like i said just throw some small spacers, or get some off a drift car.
I'm eye'ing up m2tuning at the minute, driftworks haven't got my size.
killian he just wants to the step the wheels out abit.
Keep your arches, and your wheels, you obviously want them!
Oh and I must be wrong about the spacer size, maybe I'm thinking evo or something else..
