1 Attachment(s)
180sx CA18DET Drift Build
I had every intention of putting a SR20 or 1UZ into it when (Not if) the CA18 broke but I had a think about it and decide to just stick with the CA. I had everything there already set up for a CA and they’re dirt cheap so why not right? I picked one up for about 300 quid with a cometic head gasket and 140-150psi across all cylinders.
Attachment 5153
5 Attachment(s)
Before the engine went back in I decided to give the engine bay a coat of paint. Things got a bit out of hand and all of a sudden Everything on the front of the car was getting painted.
Before:
Attachment 5154
After:
Attachment 5155
Attachment 5156
Attachment 5157
Painted the rear panel
Attachment 5158
4 Attachment(s)
Had a slight fire while cleaning the engine. Pro tip: don’t had a ridiculously hot lamp sitting on an oil soaked engine while you’re spraying flammable liquid on it.Thankfully I had an extinguisher in the car.
Attachment 5159
Eventually got the engine cleaned up, bolted everything up to it and was ready to go back into the car.
Attachment 5160
Made a hydro bracket out of 5mm aluminium.
Attachment 5161
Attachment 5162
5 Attachment(s)
Installed the 5 stud setup before the engine went in. Picked up a set of extended s14 front lower control arms to suit the s14 front hubs.
Picked up some cheap 5x114 wheels just to get her moving. Got some BF Goodrich semi slicks from a very nice chap down in cork. Friend of mine bought a 200sx off him and he threw them in with the deal. Need spacers on the front so I can get more lock.
Attachment 5163
Attachment 5164
Attachment 5165
Engine finally went back in sitting on solid engine a gearbox mounts.
Attachment 5166
Got the engine fired up and took the car out into the yard to a test drive and all went well. One or two small leaks but nothing major. I know where they are coming from.
Attachment 5167
As of today thats how the car stands. I have lights on the way for the front, a sandwich plate for the oil filter so I can add oil temp/pressure gauges, and a few small bits like fuel and oil filters and new tie rod ends.
I want to finish paining the rest of the wheels black too as I just don't like white wheels on white cars.
Will try and keep this updated. Hopefully have the car back out on track soon.
