so needed a few bits and went down to Gary Gallagher for some stuff.
i got a 2.2 quickrack
rack bushes
.70 master cylinder for hydraulic clutch
some link bars to make an A-frame kit
and a T-pull for the cutoff switch
waiting for caliper brackets to come back from the laser cutters to make my brake setup.
http://i197.photobucket.com/albums/a...r/1f6a6f87.jpg
http://i197.photobucket.com/albums/a...r/be1051f4.jpg
http://i197.photobucket.com/albums/a...r/f910e27a.jpg
http://i197.photobucket.com/albums/a...r/665ba9c3.jpg
http://i197.photobucket.com/albums/a...r/20090bf0.jpg
thanks to Dion i got a push start button, ign on switch & a proper kill switch
http://i197.photobucket.com/albums/a...627_220652.jpg
thanks to Dermot for the mondeo front caliper and paul for the cossie disks, just need a bit of lathe work to make it all fit.
http://i197.photobucket.com/albums/a...627_220556.jpg
and started on the the power steering setup and just need a lathe to finish it off.
http://i197.photobucket.com/albums/a...627_223320.jpg
as i am planning to run an A-Frame rear axle location i need to use a standard rear anti roll bar.
so philrs had a car that i could get it off of. :up:
http://i197.photobucket.com/albums/a...r/1b3238c4.jpg
heres what i was after.
http://i197.photobucket.com/albums/a...r/67a82c0e.jpg
and the quick way to get it out was cut it out :D
just need new bushes in the ends of it now
http://i197.photobucket.com/albums/a...r/23f02d9b.jpg
got a hydraulic clutch pedal box and fitted it today.
http://i197.photobucket.com/albums/a...r/17013803.jpg
and was a bit bored so i tried to make a hole flare tool for free :D
i used a wheel stud and nut and a large nut.
i drilled a 16mm hole and this is what i had.
http://i197.photobucket.com/albums/a...r/53fd9fbf.jpg
http://i197.photobucket.com/albums/a...r/cf354011.jpg
http://i197.photobucket.com/albums/a...r/10c76916.jpg[/
so made a start and finished my power steering setup.
had the escort spline welded to the corsa spindle
http://i197.photobucket.com/albums/a...704_225814.jpg
then made up all the rest and vince Tig welded everything up proper
http://i197.photobucket.com/albums/a...706_221340.jpg
http://i197.photobucket.com/albums/a...707_005013.jpg
vince also tried to teach me to tig weld but i've a long way to go to match his work
http://i197.photobucket.com/albums/a...706_224153.jpg
next was to get it fully rolling as the engine is going in this week.
just need to fit the a frame and rear anti roll bar
this is the front suspension setup and my final amount of lock aswell
http://i197.photobucket.com/albums/a...707_004806.jpg
http://i197.photobucket.com/albums/a...707_004921.jpg
painted the engine bay silver as thats what i had :D
http://i197.photobucket.com/albums/a...707_004947.jpg
dropped the 180sx and escort over to Iain and he will fit and get the engine up and running for which helps alot as these jappers are a bit of a mystery to me.
my brake setup is all ready just waiting for the caliper brackets from the laser cutters still as they got severely flooded losing €€€€'s in equip. so just being patient
hopefully the next update will be running car.
well done mate a fair amount of effort going into this!!
ah garvans old 180sx ,
nice project ya got going there she will be sweet when shes finished :)
i dropped a murphys tap off to vince and this is what he made for me, it's pure class
http://i197.photobucket.com/albums/a...r/8ee976cb.jpg
