Ill be rebuilding my Sr and have never done a timing chain engine before, this thread makes it sound difficult.
Its actually really easy. If you clean down your chain you will see 2 silver links and one black one. The two silver ones line up with the two cam sprocket marks and the black one with the crank sprocket mark.
Have you got a workshop manual? you'll need to know how to set the cam angle sensor too.
Ah ill be alrite lad, not ripping it up for a while yet cheers anyway. If ive any questions ill let ye know.
Thanks lad thats great info. Ill go counting 2moro. It does take a good few rotations to get the links lining up with the cam sprockets. Takes nearly 5 full cycles of the chain.
BUT.... As you say there's 48 rollers between the exhaust sprocket and crank sprocket [mark to mark] on the tension side, then its hard to imagine why the chain links and sprocket marks dont line up because surely there's 48 rollers from silver coloured link to yellow/black coloured link on the chain and the engine is at TDC both now the when the chain was fitted?
I dunno - depends on what rotation its stops on as u say. Cos the crank sprocket is diff diameter to cam sproc.... this takes abit of thinkin...
Thanks for the help lads.. ill try get pics up moro eve.
u should def download a work shop manual specially if its ur first time workin on an sr20....but there actually fairly simply to work on really....wen i first done head gasket in mine i thought the chain was a nightmare but got used to it an its simples really :D
Here you go.....
http://www.importworkshop.com/files/...hop_Manual.pdf
http://i621.photobucket.com/albums/t...T/DSCF0356.jpg
So overall of timing chain
http://i621.photobucket.com/albums/t...T/DSCF0355.jpg
Both black links lineing up with Cam sprocket marks,
http://i621.photobucket.com/albums/t...T/DSCF0365.jpg
So crank shaft is at correct rotation as key way is pointing 12 o clock. So engine is at TDC. But the crank sprocket mark is not in the same position as it is in the nissan manual. but the yellow chain link is correct.
http://i621.photobucket.com/albums/t...T/DSCF0364.jpg
On the above manual pic the crank sprocket mark is at 4 o clock when the keyway is at 12 clock,
BUT... on my engine the crank sprocket mark is at 6o clock when the keyway is at 12 o clock,
Can some1 tell me should the crank sprocket mark be opposite the keyway? or what does it look like on theres if any1 has 1 ripped?
The mark you are looking at now is on the oil pump drive(the round peice with the 2 flat sides)Remove that and the cam sprocket is behind that. You should see the mark your looking for then.;)
