plug out the lamda sensor and see if it reves then!!!
afm maybe?
the afm was changed on it before it's last run in mondello
we thought it was sorted,brought it to mondello and
it ran perfect for the first lap,then started limiting at 5k again
new plugs fitted yesterday,coilpacks changed for a known good set
o2 sensor changed,actuator changed/doesn't seem to be any boost/vacuum leaks
any more thoughts lads:huh:
Is it actually limiting at 5000rpm? or just revving to 5000rpm and not revving any further? Has it normal power up till 5k? Whats the spec of the car?
as pete says, stick a fuel pressure gauge on it and run it into the car and see wat kinda pressure you have when it starts acting up
try your fuel filter
i had a similar prob like this before and it turned out to be my air filter wasn"t restricting the air enough,,, silly but true changed the air filter then she ran fine... was after i changed nearly every part on the car...plugs afm coils fuel pump filters inter cooler pipes the lot... ended up getting a mad notion to change the air filter for some reason then it worked///
check all your plugs are tight if one were to come loose it would spark all over the place causing detonation... hopefully you find it
Quote:
Its revving to 5000rpm, but wont go any further when its under a load
What boost you running there. Could be hitting fuel cut?? Did you get it mapped?
