Na dude standard archs :(
i had to put 2 5mm spacers inside mine too
5mm spacer isn't goin to make the nuts any smaller though
no but if ya put 5mm spacer inside the bolt on spacer your loosing 5mm that the nut has to thread onto
Ya I know that but that's not my problem it's the nuts being too long, studs make no difference as I'll be cutting them anyway
One solution would be . to buy set of 25mm and swap the nuts with yours the 25 should be deep enough to take the ones you have then sell them on afterwards
Ya that's crosses my mind alright said I'd chance my arm at finding the nuts first though
If for example your nuts are 50mm long and are sticking out too far and you want 40mm nuts that will be flush, you may as well just cut your own ones cause either way the cut one will have the same amount of thread as the new ones you want to buy......... making sense to ya Stevie boy lol
no.............
