could be lambda sensor
it could be ice or snow melting on to a censor start the car up in a dry spot and leave it running for a while had the same problem with my legacy only i found my problem was a small gearbox leak straight onto a censor hope yours is just water:)
@serious tom Probably the temp sensor for the cat when disconnected the normally get pushed back in through the grommet underneath the seat
Check the wires on the drivers side front arch for rubbing also check the fuse box next to the afm the wires underneath the box sometimes get worn and short then recheck you fuses in the drivers side footwell after that check for loose wiring behind the dash
Were is the sensor on the blockfor the rev clock??? :confused:
Anybody? :(
Stopped working completely for a couple of days then gradually started working/bouncing then yesterday and today is working perfect!! Must have been moisture or something over the weather!!
Thanks for the help
