could be in backwards
when you say the clutch is always engaged, do you mean the turning force created by the engine is being sent to the gearbox all the time or do you mean its not sending drive to the gearbox? i cant imagine the plates getting stuck and if they did they wouldn't be long about freeing up. it sounds release bearing related or the fork Assembly associated with the release bearing. depending on what you mean by "the clutch is always engaged"
I have sen clutch plates stick together before...Happened me last year...
Just remove box, free up clutch and refit...2 Hours work
