could be the termostat is all the rad hot after you take it for a spin or is it half hot half cold if so id change the stat and flush the rad and refill with coolent/antifreeze
are they easy to replace? does the little bar goes behind the dash to the heater control??
thermostat is perfect first thing i checked
thanks a million lads im getting new coolant tomorrow and coolant flushing the whole thing see how i go from there and if i cant free the thing up im gunna replace that lil box,
keep the info coming though
dont forget to bleed the the water system make sure it hasnt air locked 10mm bolt on the top rad hose alloy housing
the little control panel by the clutch that opens/closes the hot water valve, i tried moving the bar its really hard and im afraid ill break it, which way is it meant to move
in: towards the radio
out: towards the pedals??
Bump, just wondering how hard is it to change that little box that controls the heating???
has anybody done it before?
ye no the way that sometimes people put pens in the vents to hold them ,well did you ever do that cause it pure fucks up the whole jobb it happened 2 me in the lorry twice the plastic expands and the ink drips down it2 it
