fair play man i never new that thanks:cool:
crownwheel and pinion are a matched pair, you cant change one without the other.
Look under your car, you see a big metal thing with the propshaft going into it and 2 driveshafts coming out of it, thats your rear diff casing. Its where you pour your diff oil in/out
The propshaft turns a gear housed inside the casing, thats called the pinion
The pinion turns a much bigger gear, thats called the crownwheel.
The crownwheel is bolted on a round metal thing, thats called a diff.
The number of teeth on the crownwheel and pinion is what defines your final drive ratio (diff ratio)
If there is 13 teeth on the pinion, and 48 teeth on the crownwheel, your ratio is 3.69:1. (48 divided by 13) so, if you rotate your propshaft 3.69 times, your wheels will turn once.
The gears are a matching pair, if you mismatch them, you will end up not driving very far, and making alot of iron filings!
Comprende :)
perfectly:cool:
thanks man thats basically everyting ya could ever need to no about a diff.. cheers:D:D
