I pump pedel till litle pressure open nipple pull hydro close nipple let off hydro let off pedal..:mad:
Right! This is a long shot! But iv seen this before!!!!
Have u put the rear calipers on the right side
I.E. Right caliper on the right side LOL
They fit on the wrong side before any ones asks and this leaves the bleed nipple to low so you can't get all the air out
Bleeding the back brakes with the hybro won't make a differance....! Are the 2 lines going into each caliper at the back the same lenght....! You bleed the m/c by just opening 1 of the lines going into it....!
Right il tell ya what 2 do...! Start bleeding the back driver side caliper then move to the front passanger side and bleed it...! Then move back 2 the back passanger side and finish with the front drivers side....!
And make sure your calipers are on the right way and theres no leaks in any of the lines.....!
If you do all this and and it still don't work its your m/c because i hve seen them go when let run dry...!
Good luck.... :)
Jesus just tought there lad the 2 lines going into the hydro might be the wrong way round.....! Check for that too...!
