Yea i think il do that....! Im 90% sure nigel colfer put a s15 rear subframe in his yoke something to do with grip...! I must look into it....!
mine doesnt move, but those only move a little to help turning and u dont notice!?
I never noticed my rear wheels moving like in that clip.
One of my hicas ball joints was worn so I replaced the whole lot with a Conceptua kit, it done the job and hasn't given any trouble since been fitted.
you will need to remove the hicas if its for drifting,as the hicas with try straighten the back end when you drift.as said the elimation kit is the best job and you will need to remove the pumps and all the pipework and loop it at the front so the fluid is just pumping in a loop.you wont notice it really when driving but when the back end is out it will be fighting against you
Ya iv looked into this a good bit with my 4door and the job seems to be those kits but the more I looked into it fitting a non hicas s13 seemed to be just as good an option. And the whole system is removed from the car! I'm sellin my s13subframe & all arms now but only caz I need to.
I did a bith of research on this last night and i think the best way to go is a s14 subframe with offset solid bushes...!
