coming along real well man.
Very tidy work their man
fair play keep up the great work
scary how quick its coming together :)
EPIC build!!........you probably know this but just on the kill switch, try get one with the spades on them too, and wire your ingition switch to it aswel. because if you forget yourself and try turn the car off by the kill switch and not the key the power will have no where to go and blow your altenator!! where as the ones with the spades with kill the ingition and the power at the same time!!;)
Ridiculous - that is all! :)
This is not required with the way I have wired it, once the kill spitch is turned off it disconnects the battery and aulternator from every thing else. I'm not having and "ignition switch" as the master kill will power up every thing, and a starter button to start.
Main power supply,
Black box = starter motor
Red box = Battery
Yellow box = Aulternator
Grey box = Power distribution box
Blue circle = master kill switch
This way, im using the kill switch as ignition switch, i will not have to use one of the 6 pin kill switchs, just the two pin.
http://i55.photobucket.com/albums/g1...owersupply.jpg
Indicator and hazards
centre bulb is the warning light, the arrows are diodes, the box at the top is a flasher relay, switch in the middle is the indicator switch, switch at the bottom is hazard switch.
http://i55.photobucket.com/albums/g1...irediagram.jpg
Epic epic build man.. some amount of time not to mention money going into it :cool:
Nice little write up here by Jord and Drifted
BUILD: Team Falken 2JZ Nissan V35 | Drifted | International Drifting Coverage
Cheers guys.
Bit of an update
Rear light loom
http://i55.photobucket.com/albums/g1...0sxy/044-5.jpg
http://i55.photobucket.com/albums/g1...0sxy/045-9.jpg
Fitted
http://i55.photobucket.com/albums/g1...sxy/047-12.jpg
http://i55.photobucket.com/albums/g1...0sxy/049-7.jpg
mid job madness!
http://i55.photobucket.com/albums/g1...0sxy/052-7.jpg
The two fuel pick up pots, both now fitted with new walbros, also one fitted with a -6 fitting for the fuel return.
http://i55.photobucket.com/albums/g1...0sxy/059-8.jpg
Each pot hase two pic ups, this pic is of the second pick up for the standard pot, i just ran a 8mm ID copper pipe back accross the tank for the second one and cable tied it to the tank baffles. So the fuel tank now has two walbros and 4 pick up points.
http://i55.photobucket.com/albums/g1...0sxy/057-4.jpg
Fitted and the rear half of wiring finished
http://i55.photobucket.com/albums/g1...0sxy/062-5.jpg
This is all the wires used to go from the dash back, two fuel pump lives, side lights, two indicators, one fog and one brake, The 4 little wires are for the level senders.
http://i55.photobucket.com/albums/g1...0sxy/063-5.jpg
http://i55.photobucket.com/albums/g1...0sxy/067-2.jpg
http://i55.photobucket.com/albums/g1...0sxy/068-6.jpg
Labeld up ready for connection
http://i55.photobucket.com/albums/g1...0sxy/071-5.jpg
http://i55.photobucket.com/albums/g1...0sxy/072-6.jpg
http://i55.photobucket.com/albums/g1...0sxy/073-5.jpg
Had a delivery from the chaps at Artel :worthy:
http://i55.photobucket.com/albums/g1...0sxy/077-6.jpg
Made some T peices for take off and return for the bubble tank
http://i55.photobucket.com/albums/g1...0sxy/079-6.jpg
http://i55.photobucket.com/albums/g1...0sxy/089-4.jpg
Got the cam covers back from some tig welding and gave them a dash of silver paint, was going to go blue but i think that would have been too much blue. Iv also taken to all the polished alloy under the bonnet with scotch bright to make it look less bling and chav!
http://i55.photobucket.com/albums/g1...0sxy/092-5.jpg
http://i55.photobucket.com/albums/g1...0sxy/093-5.jpg
http://i55.photobucket.com/albums/g1...0sxy/095-4.jpg
Before i scotched the manifold, pics of after coming soon as i dont it on the way out the door tonight :wack:
http://i55.photobucket.com/albums/g1...0sxy/097-4.jpg
Vac pipes for boos control, obviosly not final fitted yet, P clips and heat sheild to go on yet.
http://i55.photobucket.com/albums/g1...0sxy/100-4.jpg
