bad luck bart,
bad luck bart,
that sure was bad luck!hope she goes well for ya when back together!
Should have went for the...........
http://www.rotaryresurrection.com/kl...wapwithnas.jpg
:D:D:D:D
ok engine fully stripped...
all bits washed and some more new bits ready to go in..
mondello is looking good..
wheels are off getting painted.
will let ye know tomorrow how she's going.. ;)
he means did you torque up the caps on the con rods and measure the inside of the hole if the rods were over heated or run for a period of time with the bearings gone the hole can be gone out of shape causing odd pressuers or loosenes in one or more spot on the crank causing bearing failure,
and by the line bore i pruseme he ment that the bores (cylinders) are 100% in line and square to the crank journals if not the rod will be at a slight angle to the crank and wear one side of the bearing
car just gone to get stickers;)
