them wheels will look savage on it
really nice lookin wheels!!did ya manage to get that manifold on the engine yet lad?:cool:
oooh me like the look of that fitment, should be nice to see some tires on them and sat low!
right so here's some of the bits i'v been gathering to up the power in the car.
apexi super suction induction with z32 afm
http://i425.photobucket.com/albums/p...n/IMG_0671.jpg
nismo 555cc injectors
http://i425.photobucket.com/albums/p...n/IMG_0643.jpg
yashio factory manifold
http://i425.photobucket.com/albums/p...n/IMG_0644.jpg
megan racing a/m manifold heat shield
http://i425.photobucket.com/albums/p...n/IMG_0673.jpg
tomei rocker stopers
http://i425.photobucket.com/albums/p...n/IMG_0674.jpg
GReddy T518z turbo
http://i425.photobucket.com/albums/p...n/IMG_0650.jpg
when i got the turbo it needed a rebuild. so started to strip it.
http://i425.photobucket.com/albums/p...n/IMG_0658.jpg
http://i425.photobucket.com/albums/p...n/IMG_0659.jpg
and when i got the actuator off it, it revealed a big feckin crack in the actuator port.
http://i425.photobucket.com/albums/p...n/IMG_0668.jpg
so now i needed a new cartridge and a new exhaust housing.
lesson to anyone buying a secondhand turbo, take the actuator off and inspect the port cause you cant see around there when its in place.
so i got a new cartridge and new exhaust housing. the housing that came with it was a 10cm housing, after some research i went for the 8cm housing for more responce and quicker spool which should suit drifting better.
http://i425.photobucket.com/albums/p...n/IMG_0645.jpg
http://i425.photobucket.com/albums/p...n/IMG_0686.jpg
http://i425.photobucket.com/albums/p...n/IMG_0688.jpg
then i put it all back together so now its like a brand new turbo.
http://i425.photobucket.com/albums/p...n/IMG_0665.jpg
http://i425.photobucket.com/albums/p...n/IMG_0693.jpg
hope to get this stuff on shortly after the DI day out in goldstone on the 20th. dont want to chance it before then incase i run into any compilcations.
If im not mistaken thats gonna be a bit of a laggy bi-atch.......:D
iv looked into this a bit and the free floating bearing system that GReddy have used in these turbos are supposed to allow the turbo to spool up as quick if not quicker than many other ball bearing turbos of around the same capacity. but time will tell. we'll see when it goes on. i believe that the 10cm housing is a bit like an on off switch alright, but the 8cm is said to be a much smoother build.
Is the Turbo on the left from a Mitsubishi..?
