man thats a sickner.
you'd think it would all come in a kit, an jus pop it in..
i checked mine the time i got it for a number but notin on it , jus incase came across the problem again, looked the same as standard only the bit shorter..
might be alot of hassle, but if u bolted up the clutch , and put up the box with standard bearin an sleeve, see where it wud sit..
as i was sayin to ya already, i did this an ended up with the gap of 6mm between engine an box.. so when i got the second bearin and measured them up 6 was the difference so i new i was kinda right.......
sum hugh load of fuckin hassle to fit a clutch i know, but when ya av ta get the car on the track wat choice do ya have.............
if ya do this at least ya might no wat size sleeve ya need....
fair sick of puttin up and taken down the box though haha..:D:D
