loads of bits.. wheels n stuff
have heaps of bits i want to get rid of so jus gonna throw them up in 1 thread....
probably more will add later...
fibreglass type door cards.
similar to origin carbon ones.. not as light as bit of filler an fibreglass on them.. look cool though..
made from old door cards with pockets an speaker holes covered over with fibre glass an filled, full door card smoothed out and ready to paint....
some primer on already.. takes standard heater vents and door handle with switches, think i have a spare set there, will give with the door cards..
110 euro
ideal for drift car, need a quick sand and paint.. anyone could paint these them selves if not too fussy with a few rattle cans...
pics of actual ones
o 1 is silver and 1 white jus the colour of primer
http://i914.photobucket.com/albums/a...PHOTOS/041.jpg
http://i914.photobucket.com/albums/a...PHOTOS/040.jpg
http://i914.photobucket.com/albums/a...PHOTOS/042.jpg
have 2 180 props here with carrier bearing
30 euro ono each
4 wheels with tyres, front are fairly good, back are fairly worn bit of thread on them though.. small bit of paint comin off 1 or 2 rims as they were painted at sum stage.. be perfect if sprayed up as no dents in them.
front tyres are 205's and rears are 215's, 5x114.3
pic's as they sat on a 180 with jus 20mm front wings, was 20mm spacers on front only..
120 euro
http://i158.photobucket.com/albums/t...8022009105.jpg
http://i158.photobucket.com/albums/t...8022009104.jpg
samco joiners, all new....
joiner for intercooler pipes on s14, where pipes cross over on top of fan, in bottom of pic..
left one-straight joiner, 60mm internal diameter, 75mm long.
right one, slight bend-about 10-15 degrees, 50mm internal diameter, 95mm long..
this is for sum part of intercooler pipe set up on s14, cud nearly be used as a straight.
think these all came as a kit for s14, but shor can be used on anything, 40 euro for the lot..
http://i914.photobucket.com/albums/a...0102009127.jpg
pedal set from 180, fit s13's an that too.
20 euro
http://i158.photobucket.com/albums/t...8022009102.jpg
