Cant get the dips to work, new bulbs gone in it, wiring seems fine, fuse is fine and switch is fine coz used switch off me other e34 that works perfect!!
What else could i check???
Anyone hav a clue, its pissin me off!!!!!
did you check that you have power going as far as the bulbs
Check power at the bulbs first. If there is no power there then check the out put at the switch when its in the sidelight position. If there is no output at the switch then thats the problem, if there is, you have an issue with wiring in between.
did you check yhe relay in the fuse box?
Yeah checkd all the relays, il have a go at what the doc and moose said, nice1 lads!!!
