are the brakes on a non turbo s15 the same as the ones on a turbo or is their a difference??
no the one on spec s are only single pot brakes an the ones on a spec r are 4 pot brakes...rears are the same i think.
cud i directly bolt the 4 pots onto the front doh r will i nead 2 change stub axle?
the 4 pots should fit straight onto it alrite
i have a complete set of r33 big brake it..comes with everything you need
not reli intrested in a brake conversion just wanted 2 know will a set of 4 pots fit the front tanx anyway
the skyline ones carpo has are better version of the s15 one they ali calipers instead of steel an have bigger discs an more brakin power
how much ya lookin for da r33 1ns wud der b much of a difference in dem to da s15 spec r 1ns
