Making My Own Cage!!!!!
rite guys am goin makin my own cage with the auld lad for my 180sx. wan to do it rite. wan it to b up to spec for prodrift not saying ill ever b gud enough for to compete but at least if it ever came to dat at least cage would b a1.
wat im lukin for is gudelines wats required etc
wer its to b mount to wat size piping is required
thanks in advance....................:)
taken from the PD website
• All competing cars must be equipped with a 7 point or better roll cage. Bolt-in or fully welded Cages may be manufactured from seamless T45/T40 Chromoly, or mild steel tubing (Minimum wall thickness diameter of 2mil).
• Welds should be continuous around the entire tubular structure with no cracks and fusion must exist between weld metal and base metal.
• The main hoop shall be one continuous length of tubing with smooth bends and no evidence of crimping or wall failure. It shall be as near the roof as possible and shall incorporate a diagonal brace.
• Side hoops connect directly from the floor of the driver’s compartment and continue in one piece, as near to the pillars as possible to the main hoop. They are to be connected together by a single horizontal tube across the top of the windscreen.
• Door impact protection bars are required on both driver and passenger side. Lightweight or fibreglass doors must be re-enforced with 2 door bars in the shape of an X
2 home built cages here for ya lad, both passed prodrift scruiteny too, used i think 45mm piping and a cheap pipe benders, wasn't the easiest job but def cost effective
E30 http://www.driftireland.com/showthre...?t=3062&page=3
S14 http://www.driftireland.com/showthre...?t=4012&page=4
