Can some one explain want to buy some alloys that will fill out the archs without using much of a spacer..
the lower the offset number the closer your wheels will be to the arch. most alloy wheels are around et+38 to et+35 . these are fairly standard offset sizes. you would generally need spacers to make these sizes fill out an arch
if you go down to et +15 for example, the wheel will stick out 20mm more than the et+35 as there is 20 in the diffrence in numbers. once you get to et0 or et-10(for example) the wheels are gonna stick out from the body loads, so proper wide arches etc is required
check rimtuck.com for wheel fitment ideas, gives you gallerys on any car in any size once u input the info!
Thanks lads get it now..
