Bought a set of these for my 180. the set are for a R32gtr but i was told they would fit.
Has anyone got a thread or pictures on a brake line intall for this car. i want to make sure i do it ok never done break lines before Thanks a lot
Its pretty simple lad just a case of removing the rubber line to each caliper and removing it on the car side and screw on the new one just be carefull when removing it where is joins to the steel pipe that you dont twist the steel one it will snap very easy hardest part of it would be bleeding the brake's and that handy..
In the kit i got just 4 hose 2 short ones and two long ones. are the long ones for the back for front. the two long ones dont have the screw end just two nuts either end, the short ones have a nut at one end and a screw at the other. but the shoert ones would not reach from the calliper to the body one the front.
the long ones are for the front an the short ones are for the back man
Long are for the front for sure.. The 180 fitment i'm not sure about but should be a small threaded bolt (bout 8 r 10mm) one shed and a ring wit a bolt goin tru it the other side for the caliper the other side on all 4 hoses
Yes man that would be true fro the 180 calipers but i got five stud conv with r33 gts callipers so i got line for the r32/33 gtr i was told they would fit.
So from the body the line should bolt up but its just going on to the caliper now. both ends of the long line are the same. Sorry if im confusing ill get pics up later if it helps
If it wont fit bring them to muarry motor sport they have brake line fitting's i'm sure they'll make something up to use them..
