link g4 storm ecu an loom new in the box
bought this for my chaser witch is now sold is all new in the box never fitted cost £1200
I also have a new air temp sensor witch is included looking £750 posted pm me if intrested or call me on 07803750767 cheers brian
heres some info on it ( copy an pasted)
G4 Storm Key Features
- Built in 4 bar MAP sensor (4 bar absolute, 3 bar of boost)
- Up to 6D fuel and ignition mapping
- Precision closed loop cam control (four cam, independent control)
- Sequential fuel and ignition delivery
- Digital triggering, all OEM patterns
- Rotary - up to two rotors, fully sequentially staged injection
- OEM idle hardware supported
- 5D boost control with three switchable tables
- Motorsport features - antilag, launch control, gear cut control (flat shift)
- Continuous barometric correction (on board)
- CAN port
- QuickTune - automated fuel tuning
- Individual cylinder correction
- Odd-fire engines & two-strokes
- USB tuning cable included
- Statistics
- Gear compensation for boost control
- Real time selectable dual fuel, ignition and boost maps
- Sync and crank sensors can be a combination of Hall effect, variable reluctance or optical
- Boost control referenced to gear, engine speed or throttle position
- Up to 4MB internal logging memory
- Staged injection
- Electric blue anodized enclosure
- Power LED in the connector end of the enclosure
- Low power consumption thanks to the new switch mode power supply
- Firmware updates available online (linkecu.com)
- Brief Specification
- four injection drives
- four ignition outputs
- three/four analog inputs*
- two temperature inputs
- three/four digital inputs*
- eight auxiliary outputs
- one, thirty four pin, waterproof connector
- built in, 4 bar, MAP sensor
- 5V out
- USB to Link cable
- Link CAN connector
- Spare injection and ignition channels can be auxiliary outputs
* One digital input shares the same pin as one analog input
Quick Tune
Using PCLink, QuickTune is an interactive tuning tool that assists in time efficient fuel tuning.
A graphical display of Target lambda (desired lambda) and Actual lambda (measured lambda) is provided. A dual pointer gauge allows the tuner to quickly see how close Actual lambda is to the Target lambda. QuickTune can be setup to operate over the entire fuel table or just over a particular area.
QuickTune can be used in Manual or Automatic modes. In Manual mode, QuickTune guides you to cell centering and advises you when is a suitable time to make a fuel table adjustment. With the press of a key a calculated adjustment is made. Often only one or two adjustments are required to tune each cell. In Automatic mode QuickTune does all the adjustments for you. This leaves the tuner free to operate the Dyno or perform other tuning work such as making ignition or cam angle adjustments.
Up to Six Dimensions of Fuel & Ignition Tuning
Under most circumstances a 3D Fuel Table is sufficient. RPM is typically used for one axis with load (typically represented by TPS or MGP) on another axis. The 3rd axis/dimension is the fuel zone value.
This 3D mapping will be very familiar to the average tuner and a 3D surface representing the fueling can be easily visualised or physically displayed by selecting Surface Graph.
In special cases 3D mapping may not be adequately flexible to cope with all operating parameters.
Multi-throttle turbo charged engines typically show an example of this. With the throttle wide-open at a MAP value of, for example, 200kPa and an engine speed of 5000rpm the engine will have considerably different fueling requirements than with the throttle half open and the same MAP and engine speed. In this case the 4D Fuel Table table may be used. This second table may be spanned using throttle position on the load axis.
When a 4D/5D table is turned on, its Table Activation mode can be selected. This allows the 4D or 5D Fuel Table to become active only under certain conditions. This is useful if an external switch or switching output is required to activate the table (e.g. switching in the 4D Fuel Table when the NOS solenoid becomes active). If the table is required to be always active, set this adjustment to Always ON.
As with all tables, 4D and 5D Fuel Tables can have their X and Y axis parameters selected and their row/column locations adjusted. To do this, click on the table and press X or Y.
http://i287.photobucket.com/albums/l...ps2jmlpixo.jpg
http://i287.photobucket.com/albums/l...pseae10hf6.jpg
http://i287.photobucket.com/albums/l...psg8yadkqc.jpg
