Various R32 Skyline - Coilovers, 300ZX ECU, Engine bits.....
Full set of Japspeed Daiyama Coilovers R32 GTST with spanners, SOLD
Cusco Strut brace, ends painted poorly, some surface marks. €60
http://i298.photobucket.com/albums/m...ps699dccff.jpg
Walbro 255lph fuel pump, sold
RB Genuine N1 Oil pump. Run on the dyno for nearly 4 hours before the bearing
on Conrod 2 picked up. No loss in oil pressure, suspected badly ground crank was the fault.
The pump had bits of bearing run through it but has no marks on the housing, you can see some of the bearing in the photos.
I tried removing the bearing left on the pump surface as you can see from the marks in the photo. I'd be happy to
use this pump again since any bearing can only go to the filter next but the customer wanted a new one.
Since I couldnt remove the bearing myself, it doubt it come off on its own. Pump is still apart so you can inspect
it yourself. €100
http://i298.photobucket.com/albums/m...psa5e1416e.jpg
http://i298.photobucket.com/albums/m...ps74cac8b2.jpg
http://i298.photobucket.com/albums/m...pse1535fda.jpg
http://i298.photobucket.com/albums/m...ps4fdb04b6.jpg
http://i298.photobucket.com/albums/m...ps159af5d9.jpg
Braided Oil line for RB engine, made for Garret 3071 in standard fitting position but should fit others. €25
http://i298.photobucket.com/albums/m...ps1f6c4246.jpg
Exhaust wrap. 10 metres brand new. €15
http://i298.photobucket.com/albums/m...ps7d71019b.jpg
300ZX ECU SOLD
Good low mileage R34 Starter Motor, will fit other RBs. €50
http://i298.photobucket.com/albums/m...pse1f70396.jpg
Brand new Japspeed tension rod stabilizer bars - €50
http://i298.photobucket.com/albums/m...ps4a9334c3.jpg
