TDP SR217 Engine, (redtop none vvt)
right so i did this engine with the intensions of fitting it to my ps13 but that project doesnt look like its going to be doen any time soon so no point haveing money tied up in it and sitting there not being used when i could do with the few bob to finish off some other things,
currently the engine sits fully machined cleaned and stored in boxes and all new parts are still in there original boxes it will be for sale in a new built engine form only not in parts, if you were interested in the engine as the spec is that fine it will be a small deposit up front and then the engine will be assembled, or if you wanted to change/add to the spec of parts ect that can be discussed.
current spec as fallows:
SR20 redtop block with custom TDP SR217 heavy wall liners fitted, CNC bored/surfaced, honed
SR20 redtop head with custom TDP SR217 CNC chambering and surfaceing
custom TDP SR217 wossner forged piston kit NEW,
valve seats recut,
valves polished,
HKS valve srings NEW,
ACL race series main bearings NEW,
ACL race series big end bearings NEW,
ACl dura glide trust washers NEW,
ARP headbolt kit NEW,
Cosworth metal head gasket NEW,
Blueprint water pump NEW,
Nissan oil pump NEW,
Nissan s15 specR crank shaft balanced and freshly polished,
Nissan s15 specR con rods,
Nissan s15 specR timing chain,
Nissan s15 specR timing chain guides,
Nissan s15 specR timing chain tensioner,
Nissan s15 specR rocker arms,
Nissan redtop sr20 cam shafts,
all above from low millage engines,
the sr20 engines used for the build was a perfect running engine and had not suffered failure before stripping so the block and head ect are 100% trust worthy,
as said i have no problem altering the spec adding forged rods diffrent spec cams ect ect but at your cost, the engine is not assembled yet either way so no extra labour charge,
the engine will come with a nissan cas sensor fitted and an s14/15 aux belt pully fitted, it will have an oil filter housing fitted,
it will come with inlet manifold, thermostat housing and water pipeing
PRICING by PM only either post here pm me or on fb and i will contact you, i no this is against the site rules but so is alot of other stuff that happens here lol
