s50b30 in an e30 4 pot info wanted
im seriously looking at putting an e36 3.0 m3 engine s50b30 into an e30
the e30 is originally a 4 cylinder
so obviously i need the
- engine
-engine loom ecu
-gearbox
-propshft
-radiator
but here are where my questions start
i dont need the key etc if i go alpha n right ?
will the manifolds work without modification ie. clear the steering rack
what do people do for mounts or do the match up
does the standard sump work- clear the subframe ?
do i need to uprate the fuel pump (i assume i do)
is there a wiring pinout done for this conversion
is there much wiring to this conversion if i use alpha n
just positive and negative and switched positive to the ecu or is there more ??
have looked around on the internet but havnt all i found were pictures of completed conversions really !
just trying to get an idea what involved in this conversion
