IM not sure if this is considered technical or not but how do u stop ur fancy clear tail lights from fogging up with bubbles and looking rediculous
normally drill a smal hole in it somewhere on the bottom of them and it lets the water out and air in. problem solved
I've heard of lads opening them up and throwing in a few of those Silica Gel things, the things you find in new shoes to soak up moisture
theres water gettin in so just drain in and seal it back up with silicone....if you dont mind doin that.
yea no need to open the light at all just put a little hole in the bag of silica gel bag tie a bit of thread to it stick it in on of the light and wen its all gone just pull the thread and the bag will come out saves time and heart ache:D
make sure you take out most of the water first or it'll take weeks to dry out
salt also clears up moisture as well
