ECU for JZX81 1JZ
Ok this is a long shot, but has anyone (Chuck/Raff maybe?) an ECU to fit the above? Not even for sale, but maybe so i could plug in just to see if my ecu is knackered, you could have it back and at least id know to get one. If anyone has one for sale id be interested also
Cheers :)
Its not the resistor gone in the Ecu is it lad??
I dunno to be honest. Me and electrics dont get on, i havent a clue! I do know after opening the ECU last night that some of the capacitors are fucked. My friends dad builds circuit boards so he said he will have a look at it and see f he can fix it up. May not be my problem though but if there was another ECU lying around i could at least try it and see it if works.
You hardly have one do you?
Ah I see your pm and i raise you a reply! ;)
Cheers
if you have no luck with the above ya can come down and try mine, as long as ya dont blow mine!
Thanks mate, I might be sorted with Chuck, if not i'll deffo give you a shout. It shouldn't do any ECU any harm, if the blown capacitors are the issue then they have gone from old age as apposed to something else killing them. So i believe anyway!
Thanks again pal :)
