My 2013 S14.5 Driftfest/Superdrift Seat time car
Right alot of lads know i have this and for once im doing fuck all buying parts, upgrading bits, then losing interest in a car.
This is as ready as it gets really, the ex MG crash repairs/Paul murphy S14.5 and been honest she's well put together with all the right bits needed..
Due to work commitments i have to work saturdays, so hopefully i can find somebody to fill in so i can do a few rounds this year.
Spec that was listed and bits that have been figured out since.
1998 S14 Silvia shell
ENGINE/Transmission
SR20DET vvt engine
Custom engine loom
Wozner Pistons
New followers
Cosworth Head Gasket
ACL race series bearings
Nismo 550cc Injectors
Brand new 2871R Turbo
Braided turbo lines
Adjustable FPR
Alloy radiator with twin fans
Adjustable actuator
New 100mm Front mount intercooler core with custom pipework
3" Turbo elbow
3" Downpipe
3" Decat
Driftworks shotgun back section
OMEX 600 series ECU mapped to 410HP by TDP.ie
Exedy clutch
Nismo lightened flywheel
SR20 Gearbox (for now)
Welded diff
EXTERIOR
Fiberglass vented bonnet
30mm vented front wings s14.5
50mm Rear quarters
Side skirts
New back bumper ordered
S15 headlight blanks
S15 front bumper
External cut off
INTERIOR
6 Point through dash bolt in cage with welded X door bars
Fire extinguisher
Push button start
Cut off switch
Center panel with wipers, fuel pump ect on switches
Hydro handbrake
OMP Bucket seat on adjustable rail
Schroth harness
OMP Dished suede steering wheel
Drycell battery
Again Custom Brendan stone loom all factory loom and switches removed
SUSPENSION/HANDLING
Driftworks geomaster front hubs
Driftworks rack spacers
Driftworks tie rods and ends
R33 brakes all round with braided lines front and rear
Brembo rear grooved discs
K-Sport Coilovers with adjustable top mounts
Adjustable castor arms
Adjustable Toe arms
Adjustable camber arms
R33 rear subframe with hicas lockout
WHEELS/TYRES
SSR integrals 17x9.5 just powdercoated (now changed for Volks)
VOLK GT7's 17X9 ET+2 all four corners
Maxsport front tyres
25mm Spacers on the rear none on the front
PICS (NOT ME DRIVING)
http://i47.tinypic.com/v5d6pk.jpg
http://i49.tinypic.com/fu01fr.jpg
http://i48.tinypic.com/3537gnb.jpg
Few bits done since i picked it up, Turbo lines changed.
De-stickered
Wheels changed
And to be fair nothing else needs to be done its ready to slide, ill try it with the diff ratio fitted for mondello on the 10th and gauge if i need a shorter ratio diff after that.
Wheels changed
http://i45.tinypic.com/98da1v.jpg
Stickers removed
http://i45.tinypic.com/2qxm63d.jpg
http://i46.tinypic.com/166k51j.jpg
http://i45.tinypic.com/34pe7ww.jpg
http://i47.tinypic.com/110vf54.jpg
http://i45.tinypic.com/wamyz7.jpg
