bmw E30 engines/engine parts
here we go:
M20b25 block with good crank and 0.25 oversized pistons in it-120
M20b23 crank (alpina 2554cc stroker when used in b25 block)- 80
M52b28 crank with adaptor for front oil seal-120
M20b25 (755casting) ported head with valves and springs-200
Set of m20b25 standard size piston rings (new)- 100
set of m20b20/23/25 big end bearings 0.25 oversized (new)-80
Set of m20b20/23/25 main bearings 0.25 oversized (new but box opened)-60
Set of m50b25 piston rings standard size (new)-100
Complete m20b20 engine+ecu+loom out of e28 with 106k miles, was running smooth- 100
recently rebuild m20b25 about 5000miles on it- 350
Various m20 standard cams 30 each
m20b20/23 head (200 casting)- 60
3x m20 sumps aluminum- 70each
2x m20 sumps metal- 40each
m20b20 intake manifolds, m20b25 intake manifolds, injectors, throttle bodies, fuel rails 5-10 euro each
genuine reasonable overs taken on all above
best way to get me is on 0857796399
Thanks
Tomas
