87 wob Levin built 16v,trd box,10J meisters €10000
right guaging intrest in selling this not pushed so wont be taking any offers..just want to finish my track car and things
87 Wob jap levin
full vertex kit
runfree rear arches
trd rear boot wing
seibon carbon bonnet
redline rear lights
trs pink tow strap
nct'd and tax'd 02/13
suspension:
cusco top mounts
coilovers with mcn/avo inserts
30mm rca's
aftermarket tension rods
manual rack
hardrace rose jointed track rod ends
extra lock tie rods
uprated rear anti roll bar
tokcio red rear shocks
lowering springs
front and rear strut braces
Brakes:
drilled and grooved disc's all round pbr pads
aftermarket brake stopper
braided lines
Hydro with new girling .625 braided lines
wheels
Work equip 01's 9x15 -15
Work meister s1's 10x15 -38
running gear:
Built 4age 16v from Diarmuid connells ae86
its 176bhp and 135ftlbs
omex 600 ecu and full wiring harness mapped by tom casey
coil pack and leads
head polised and ported
272 degree cams
adj pullys
itbs and trumpets, (silvertop)
technotoytuning adapter plate
trd .5mm head gasket
82mm 11.8:1 wossner hi comp pistons
hi tork bottom end ( balanced and polished)
acl bearings
arp bolts
toyota oil pump and gaskets
hks shim kit for oil pump
last few months head re-done with
Head skimmed
new valve oil seals
exhaust manifold studs completely redone
ARP head bolts
HKS purple timing belt
0.5 trd headgasket
ledwith dizzy blank
Zaleek clear cam cover
TRD oil filter
Castrol magnatech oil
reduction starter
custom throttle cable
DMAC martellius touge shotgun exhaust
HMturbo alloy rad
TRD rad and oil cap
red rad hoses
Omori oil filter relocation
trust oil cooler
TRD short ratio gearbox
Exedy paddle clutch
Driftculture light weight flywheel
late spec rear axle cusco diff 4.3 cwp
bosch fuel pump
interior:
Bride drivers seat
full interior fitted inc parcel shelf
full dash doger roll cage
Bride tacho guage
hks oil temp water temp and oil pressure there to be fitted
car does need repair the passenger inner arch slight rush needs metal replaced can send pics to anyone intrested its not bad
thats all i can think of atm probaly a few more lil bits and pieces
Price for full car wheels everything is €10,000
will sell the car for €8500 with out wheels
serious offers only i will not entertain time wasters no cash no drive no rush to sell ive already turned down 7500-8000 offers without the wheels so dont waste your time and mine......
