As above lads I'm looking for the boost control kit off the power fc .
Here's a pic of what I need
http://i565.photobucket.com/albums/s...7D599F2ED0.jpg
Anybody got one lying around??
Cheers
Cheers
I was going to go that route before dude and I read up on it and I rang around and absolutely everyone said the power fc is terrible for controlling boost and I would be much better off with a seperate boost controller
Yeah I've heard good and bad about them but more so bad !!
Cheers lads
I use one never a problem?
You can buy the wire and actuator off couture dauto think it was €15 for the cable and pressure sensor and the actuator/solonoid is €30? I have part numbers some where if you want them?
Most say the AVC-R is better for controlling the boost because of predictable gear shift boost patterns or something allong those lines.
Yeah if you have the part numbers that'd be great dude
Cheers
No worries, its all written in the PFC manual, sonny was getting rid of alot of stock when i got mine he might still have some left.
499-X001 MAP Sensor
49C-A002 MAP Sensor Harness *This is the 3 pin one i used. But 49C-A004 is the 5 pin harness check your pfc.
499-X003 Actuator/Solinoid.
Your a legend dude :)
