anyone for swaps
i havent even finished my current project but im all ready gathering parts for the next,
i only really want to swap these parts as ill only be cutting them up to suit what i need anyway
1, r32 gearbox and prop push type,will swap for good rb25 gearbox and prop other wise ill cut the transfer box off and use it rwd
2, rb26 sump with diff,will swap for a already converted rb26 rwd sump ,or rb25 extended sump,otherwise will cut off diff and weld up
3 rb26 inlet manifold and throttle bodies ,will swap for a after market rb25 inlet manifold ,or will buy the conversion plate if someone has one
4,rb26 looms and ecu,looms are cut so for bits really,
will swap for rb25 loom
5 loads of 26 engine bits,standard,pistons rods,engine mounts etc,will swap for rb25 bits
6,rb26 flywheels and standard clutches will swap for rb25 clutch
im in no hurry with these bits as it will be into next year when i need them so if you have some from when you had a rb25 and would like to swap them that would be great thanks ,damian
__________________
