I have one of these and the housing is too big on it and is fouling another sensor
http://images.gasgoo.com/MiMwMDRfMDA...ure-sensor.jpg
So I need one smaller than this, also the probe can't be too long on it
Anybody have one? Thanks
Really in need of one of these asap hence the early bump!
To the top
Any motor factors or agri supply store will have a smaller oil sender 1/4 the size of that but wether or not the signal for your gauge will be ye same can't say.
So its not possible to determine the signal then?
Yeh depends, some gauges (redpower, swoosh?) will only use the sender you have pictured Ive had the same problem with clearance, and took out the factory oil pressure switch (sr20) and put that in but on another car with autometer gauges I bought a sender from bradshaws in newbridge and it worked so depends on the gauge.
thanks man
Is this for oil pressure guage or for a low oil pressure light?
did you buy that one of amazon ? ^^
there 2 solutions for you depending if its low oil pressure or if you want to use that guage !
This is possibley the best solution...
T-Piece 1/8 NPT - Demon Tweeks
Or Get the pair of these guys...
Twin Split for 1/8 NPT - Amazon (im 99% sure its 1/8 NPT, but mail them to check)
1/8 NPT Thread Plug Bolt
OR
For Low Oil Pressure Sensor (they will try charge you something like €16 to deliver it so just give them a phone call or email & tell them that the delivery is over priced & you where onto a mate of yours and they delivered it for £6, which is true because i got after them about it)
Low Oil Pressure Sensor - Demon Tweeks
Low Oil Pressure Kit - Demon Tweeks
Just for a sender for a gauge dude. The oil pressure sender is fouling the oil temp sensor and wont thread in fully. So one of the top ones should do, thanks for that dude!
