story lads the front meisters look like someone got sandpaper and startd to have a go at them. is there a quick and easy way to get the shine back ? like a polish or compound i can apply with a buffer.
If they already started sanding, You best bet is work through the grades from 400 up to about 2000 and then use Autosol.
It's tedious but worth it :)
wet and dry and a good going over with mothers on the end off a buff ball/cone
When changing grades switch directions so you know your removing the previous grade or Give them to me lol
Sorry for the bit of a hijack
Kruizer what do you use on the wheels after you've polished them up to protect them again, do you use laquer, wax or anyhting like that
