As above for a large case diff
must be reasonably priced
You wont get 4,10 ratio in 210 casing lad, 4,10 is rarely available in 188 case, and all 210's are low 3's and some automatic 5ers or 7ers were in around 3,7x and rarely enough you can get 3,91, will have a look if my mate can sort you out on smth as high as possible in 210 size
they have them here, but theyre not cheap
http://www.diffsonline.com/product/gearsets.shtml
Thanks was thinking it wouldn't be handy got ave got a 188mm 4:1 in
My 3l m3 and took a lad a run up in aghadowey now he mad ta get
One for his evo
He can always fit 188 into evo... Bit a hassle but its easy doable
Are the internals of the diffs the same ?
no, i think tomas was saying to swap subframes ect to get the 188 to fit.
Pm valdas bmw on here...........
Mick Barry has them here in Cork. Should be able to source a casing for you too.
http://www.barrysmotorsport.ie/
Might be better to go something like 3:91 then so ta keep the cost
Down 3l rear end not that handy got
