Volvo 940
1996 Volvo 940 2.3 turbo for sale,
T5-r turbo fitted with heavily ported hotside and uprated actuator.
Heavily ported exhaust manifold
3" turbo back exhaust
Modified airbox
Mbc running 1.1 bar(will take plenty more if set up with wideband + knock monitor but 1,1 is safe)
Blitz boost gauge
RSI stage 2 cam
Nuke performance Adjustable cam pulley
T5-r Me7 blue injectors(running 400cc with modded FPR)
Chipped Ecu
Chipped Ignition control unit
Modified to run wasted spark ignition mod which also gives flat shift and launch control(allows you to build about 6psi of boost at 3000 rpm in neutral and causes serious exhaust flamage:evil:)
Lightened flywheel
Heavy duty clutch(fitted last week)
Modified camber and castor
New Koni yellows adjustable all round + lowered
Uprated front ARB
Double rear ARB
New Walbro 255lph pump
New timing belt last April
Fully serviced with Valvoline fully synth 10w40
Fully synth Valvoline synpower gear oil
4 x 90% tyre + 2 good spares(90% thread as well)
Welded diff and comes with spare rear axle
Serious lock as standard.
Not tested but ran through the test and only needs a temporary cat bodged in to pass, everything else was 100%
Not stanced, not pretty, won't get you laid but its a Genuinely quick Vulva and the law doesnt look twice at it, stealthdrift ftw:afro:
Big comfy car(heated seats for the winter warm bum goodness)
€2200
pics and/or vids asap!!
purely because i like volvos!
God i love the sound of this. Pics pics pics!! PRONTO!!!
I have no pics at the mo but it just looks likes any other dirty/scruffy 940 Vulva from the outside which is they way I wanted it for the stealthishness:cool:
I only have videos of exhaust flamage which I'll upload tomorrow, no in motion vids.
Similar launch control/flat shift set up, not nearly as loud or as many bangs though:cool:
940 launch control - YouTube
I'm big into Volvo's i have A 740 I drift I plan to make put a 2.5t T5 engine into it this winter...If you decide to brake your car ill take a few parts off you mainly suspension....Would not be into spending 2,200Eur on a 940 even tho it sound nice...
