Sr20det bits and bobs!
Need some bits guys for a black top non vvt sr20det
sump, full sump/front pan and alloy sump.
Late s14 water pipe on the right next to the ps pump and bolts..The one with the treaded hole that that a water line can bolt onto!
gearbox bolts
flywheel bolts
pressure plate bolts
oil filter houseing that bolts onto the side off the block
i have the alloy sump and the oil filter houseing off a red top if any good to u
How much?and wear are you?i must check are they the same,im unsure.
as far as i know they are the same i'm in charleville co,cork on the limerick boarder 100 for the 2 of them
Have everything you need give me a ring 0872572673
have it all here from a vvt engine but im 99 percent sure their the same.. im in carrigtwohill
Back on the hunt for these bits if anyone has any?
still have the alloy part of the sump if u need it
have an engine that had a knock in the bottom end,its in parts in two boxs, 100e takes the lot,sump etc, hks vvt sprocket included
