Getting a set of rota gtr's for my 180sx just want to know what width and offset would I need.
have you standard wings and rear over fenders?
Ya all standard
A 17 X 9 should fit grand with a small flare
what off set should i go for?
I put a 17 X 10 et 12 on the rear of my 32 with standard arches just rollled/small flare and they fit not a bother...
The 17 X 9s only come in et25
i had et35 on my r32 they were 18 x 9.5 front and back.arches needed to be a little bit of rolling. i had a 225 front and rear with a stretch tyre.but id try a go as bit bigger to save kerbage.
make sure you get the dished in type. i had 17x9 et25(25mm spacer on back) and they were just about enough on my wide arch 180, so you might have to roll your wings.
Go for et 12 on a 17 x 9j rim will look good with the car droped on them
It depends on how much camber you have, how low the car is and weather you want to roll your arches or not. I have 17x9.5 et 26 on the back of my car and it was fine with standard arches with the lip rolled, until I straightened the camber then I had to roll the arches out.
