S13
I have limited access to the net at the moment so bare with me while I update the thread with parts and prices and pics;
CA18det engine, gearbox (very tight) loom and ecu, with nearly new exedy clutch, flywheel needs skimmed. In great condition and can be seen running before taken out of car. €700 - May sell separately if it sells quicker that way!
All adjustable arms for rear. Upper and lower control arms and toe arms €70 a set
Subframe - painted red with solid alloy bushes €100
Aftermarket Polybushed anti roll bar €40
Struts front & rear brand new (look to be cusco???) €120
Magnum FIA approved but out of date fixed back seats €250 the pair
Monster dish steering wheel and boss €100
Rear S14 na hubs €50
Driftworks Hydro and Lines €120 has only seen 1 days use!
Welded diff (wont no ratio until I take it out will post price then)
€50 for the homemade turbo back exhaust - not the breast now to be honest
HPI Front mount with piping €250
HKS adjustable actuator - has been modified - excellent cond. though - €50
Almost sure its a T28 from 14a - will double check when take it out €130
Short shifter - dont know make €40
skid wheels - 4 16" advans sprayed white and before that green, 70% tyres - €100, 2 17" cheapo multi spokes white with good tyres €70, 3 standard S13 15" rims - €70 - or the lot for €200 and will throw in a some good part worns
will try get rest up later
I'll take the hydro off you lad you have a pm
What make are the arms, any pic's of the wheel ?
Dont know what make the arms are - They are much chunkier than the driftworks stuff i've seen though. I will throw all pics over the next day or two when I get a chance. Only have the net in work at the moment so have limited access
